Route between LAN segments
Gremlin99Z
in Home Router
I have a EX3510-B1 (AX5700) Ethernet Gateway. Besides the Default group, I have created a "Camera" group for my security cameras, assigned LAN2 to the segment, and setup the IP segment for this LAN segment. From Camera LAN, I can reach other hosts on the Default group but I can not reach the Camera group from the Default group. What is the best way to enable two way routing between the groups?
HI~
Although direct routes are typically generated automatically for different segments on the same device, please double-check the following:
- Client Configuration: The Default Gateway for both the cameras (Camera Group) and the PC (Default Group) must point to the EX3510-B1's IP address within their respective segments.
- Static IP Settings: If the cameras are using static IPs, ensure the Subnet Mask is configured correctly; otherwise, return packets will not be able to find the correct path.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
