WX3100-T0 Power Lead Extension
MothFeatures
MothFeatures Posts: 2 image  Freshman Member
Hi there, we have a WX3100-T0 from our fibre provider, but the location of the line in to the house is causing some problems, with one wall in particular blocking the wifi. I would like to place it about 7 metres away from where it is, but I can't seem to find a cable that would allow me to do this. We don't have a socket any closer, and a regular power strip extension is too thick of a cable for trailing through. This also prevents me from using the extender in that location.
Part of the problem is I can't find any specifications for the size of the barrel for the power connector, but I would also make sure I'm picking something safe/appropriate. Any suggestions for this would be greatly appreciated!
TL;DR: Is there a suitable power extension for the WX3100-T0, failing that what are the size specs of the power cable's barrel?
  • CryBananaCat
    CryBananaCat Posts: 63 image  Ally Member
    HI~
    I suggest contacting your local service provider for further assistance. As power specifications differ between EU and US regions, they can confirm the exact connector size and power requirements for your device to ensure compatibility and safety.
