NWA50BE Nebula License
WileECoyoteIT
WileECoyoteIT Posts: 3 image  Freshman Member
I have a Nebula PRO license.
I would like to add a NWA50BE Access Point. I suppose I have to buy a license.
Which code?
LIC-NPRO-ZZ2Y00F is correct for the 2Y license?
Thanks!
  • Zyxel_Tina
    Zyxel_Tina Posts: 729 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited March 3
    Hi @WileECoyoteIT,
    Regarding your question about the license code LIC-NPRO-ZZ2Y00F (2-year license), this is a license part number. The actual license key is a 21-25 character alphanumeric string.
    Here's the information for your reference:
    • License Requirement: To use Pro Pack features across your organization with the NWA50BE, all managed devices within that organization must have a Nebula Pro Pack License. If your existing Nebula PRO license covers all devices in your organization, and you add the NWA50BE, you will need to purchase an additional Nebula Pro Pack license for the NWA50BE to maintain the Pro Pack features for your entire organization.
    • License Activation: Once you acquire the license key, you will need to register it in Nebula under Organization > License & Inventory > Licenses. After registration, assign the license to your NWA50BE.
    • Organization Upgrade: After all devices in the organization have the appropriate license, an "Upgrade Now" button will appear under License & Inventory > Overview in NCC. Click this button to upgrade the organization to the Pro Pack level.
    Zyxel Tina
Nebula Tips & Tricks
