Zyxel USG FLEX 100 Loopback Interface For IPsec remote access VPN
younes
younes Posts: 3 image  Freshman Member
Hello everyone ,
I have a Zyxel USG FLEX 100 pinging 2 ISP routers using a BGP session with a private interco. The Internet is already working with a NAT object.
I already have an IPsec remote access configuration, but it's not working because I don't have a public IP directly on the interface.
I'm not able to create a loopback interface on the router .
How can I solve this issue?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @younes
    In this scenario, you should set NAT rule on the ISP router since the USG FLEX 100 is behind your ISP router's NAT from the Internet.
    Zyxel Melen
  • younes
    edited March 4
    Thank you, Melen, for your reply. I will check with the ISP if it's possible to do NAT on their side.
    Otherwise, is it possible to create a loopback interface on USG FLEX 100?
