NWA50BE PRO Temperature
i bought a NWA50BE PRO, it runs fine so far but i'm concerned about the devices operating temperature. the case is hot to the touch on the back, its mounted to the ceiling (concrete). is there a way to check the actual temperature? i found nothing in the ui, it runs in standalone mode.
thank you in advance.
Hi @DesertH2O,
Welcome to the Zyxel Community!
The NWA50BE PRO is designed for optimal performance within specified operating temperature ranges. While the device doesn't support checking its internal temperature through the local GUI or CLI, if your environment meets these conditions, the warmth on the back from normal heat dissipation is expected.
Zyxel Tina
Hi @DesertH2O,
Zyxel Tina
Hello Tina,
thank you for your reply. I bought a infrared thermometer and the backplate is around 55°C, in a spot near the qr code its around 60°C. i'm trying to play around with the transmit power a bit.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
