XS 1930-12HP link speed settings in aggregation mode missing (Nebula Cloud Interface)
I want to create an aggregated link between my GS1900-24 and the XS1930-12HP with 2 DAC cables on the SFP ports.
If I configure the individual SFP+ ports and set the link speed on the XS1930 to 1G (because GS1900 only supports SFP = 1 G) then the links work fine. When I then aggregate the two ports the link setting is overridden and returns to AUTO on the XS1930 and the connection cannot be established.
In Nebula Cloud I am not able to change the link speed setting of the aggregated ports. And, contrary to the note that appears in the aggregation dialog, the settings of the lower port number are not taken over by the other port(s).
Please advice how to solve this? Is it possible to change the link speed in the local management console?
Thanks!
Got it working. I had to set the ports to Auto/1G before making the trunk.
If a fixed link speed of 1G was set it reverts to Auto during aggregation.
But if it is set to Auto/1G it stays on Auto/1G.
Would however be better to allow modification of the link speed also in aggregation.0
I think the 1G is not the point because both switches have auto negotiation on switch ports.
You should configure port media type to 'DAC 10G' instead of SFP+ on the two ports of XS1930 before aggregated them.0 -
Thanks, but I have already set it to DAC10G and still the same.
I think the auto negotiation doesnt work properly, because in auto mode I do not get an active link even without aggregation.0 -
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
