API flexh series
Dpj
Dpj Posts: 215 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I was wondering when the h series are compatible with the API. As far as i know at the moment i cannot retrieve information from the H series.
3
3 votes
Completed · Last Updated
Already support Nebula OpenAPI for USG FLEX H series.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,679 image  Zyxel Employee
    Hi @Dpj
    May I know if you encounter any issue when using the Nebula OpenAPI > GW API on USG FLEX H? Since these APIs have supported USG FLEX H series, please let us know if there has any issue. We have verified these APIs are working. Or, do you mean you hope can support more features via using APIs?
    Zyxel Melen
  • Dpj
    oh, i totally missed this message.
    I directly will try
  • Dpj
    seems working yes.
Nebula Tips & Tricks
