Armor G1 only cloud???
Melak
in Home Router
Cant you configure your router without using a cloud account? I dont want to have my router config saved on someone elses server/machine? Can you login and configure your own local router without a cloud account, and if so, how? Thanks in advance
Hi @Melak
Thanks for your valuable suggestion.
Currently, Armor G1 needs to register an account for the app using.
After register an account, when access WEB GUI, there are two login type can choose, cloud account login and local password login.
You can choose local password to login device.
Best regards,
Jerry0 -
hat is exactly the problem: I am never given the option to choose between Cloud or Local access.
As soon as I hit the IP
192.168.123.1, the router immediately redirects to theeasy123SingleSignOnpage. Instead of showing a login form or a 'Local Password' button, it attempts to contact the Zyxel servers, fails, and displays the error: 'We are experiencing some service issues. Please refresh the page or try again later.'The UI-router is stuck in a mandatory cloud-check loop (ZAPI error 4142) that prevents the local login screen from even loading. I am effectively locked out of the device because the 'Local Password' option is hidden behind a cloud handshake that is currently failing.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
