ntermittent WiFi clients unable to obtain IP / no Layer 2 connectivity – NWA130BE (Nebula)
We are experiencing an issue within our wireless network where client devices intermittently fail to connect to the network.
Environment:
- AP Model: Zyxel NWA130BE
- Switch Model: Zyxel XMG1930-30HP (We do have other HP switches as part of the LAN network)
- Management: Zyxel Nebula Control Center
- Firmware:
- AP: V7.30(ACIL.3)
- Switch: V4.80(ACAS.4)
Symptoms:
- Clients connect to SSID but show “Connected, no internet”
- Devices receive 169.254.x.x addresses
- Issue occurs across multiple APs
- Wired connections function normally
- In the nebula portal Its states" xx failed to receive an IP address due to DHCP failure/timeout…"
Troubleshooting performed:
- DHCP scope checked (83% free)
- DHCP services restarted
- Lease time reduced
- Static IP assigned → still no connectivity
- Tested across multiple APs
- Verified RF/channel utilisation (low usage)
- Confirmed no DHCP snooping configured
- Packet capture performed
Packet Capture Findings:
- DHCP Discover and Request observed
- No DHCP Offer received by client
- Repeated ARP requests:
- “Who has 10.x.x.x”
- No ARP replies received
Key Finding:
Even with static IP configuration:
- Clients cannot communicate with gateway
- ARP resolution fails
I believe this indicates:
Layer 2 return traffic is not reaching wireless clients
Impact:
- Intermittent loss of connectivity for student/staff devices
- Affects multiple APs and locations
Request:
Please advise if this is:
- A known issue with firmware V7.30(ACIL.3)
- Related to AP bridging/forwarding behaviour in Nebula mode
And recommend:
- Firmware version to downgrade to (if applicable)
- Any known fixes or patches
Many thanks in advance 😀
Hi @SWalker
Could you help to enable Zyxel support access and share your organization's name so we can help to check this issue?
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
