VMG 3625-T50B Login Error after Firmware Update
cozpolat
cozpolat Posts: 2 image  Freshman Member
I was using a firmware version which ends with G0 and I upgraded it to the V5.50(ABPM.9.4)C0
The problem is; when I reset the router, the default login password at the back of the router doesn't work anymore. I tried different combinations such as 1234, admin, password, etc. but no luck.
What is the root cause of this problem and how can I solve it?
(Please do not suggest foolish solutions like reset it again or push the reset button 5-6 secs… I already know how to reset a router )
Thanks.
  • CryBananaCat
    CryBananaCat Posts: 63 image  Ally Member
    Hi, G0 is totaly different to C0, so it is normal that you cannot login, because the set up is differnet.
    please contact your local service representative for further assistance.
