VMG3312-T20A full factory firmware (with ROM-D)
I am looking for a full factory firmware image (including ROM-D) for a Zyxel VMG3312-T20A.
My router seems to be ISP-customized. Even after a hardware reset, the admin password printed on the label does not work.
This strongly suggests that the device is using a custom ROM-D configuration from the ISP.
The firmware available on Zyxel support pages is only a very small upgrade file (~20 KB) and does not overwrite ROM-D, so it does not restore default credentials.
I have serial access to the bootloader (ZHAL) and I want to:
- flash a full factory image with ROM-D
- using TFTP from the bootloader interface
I am looking for any of the following:
- full factory firmware image for VMG3312-T20A
- ROM-D image
- full flash dump from a non-ISP / generic device
- recovery image that restores default admin login
If anyone has such an image or can share it (publicly or privately), I would be very grateful.
Thank you very much for any help!
HI~
If the FW is customized, please load the customized FW to login, otherwise it will not match the label.Please contact your local service representative for further assistance
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
