Recovery Steps for USG FLEX/ATP Series Application Patrol Signature Issue (Jan. 2025)
1235»
  • MikeForshock
    MikeForshock Posts: 66 image  Ally Member
    Sure would be nice to be able to roll-back these updates to signatures as a separate process
  • MikeForshock
    Incase this issue is still lingering for others. This process recovered two of our units, but does not follow this guide exactly and your mileage may vary.
    Reboot router
    Login via webui
    Download config and enable FTP (quickly, before it locks up!)
    Reboot router again
    FTP into the router, upload the date firmware provided to the root folder
    Router should reboot automatically.
    Login, force signature updates (DO NOT UPDATE FIRMWARE IF PROMPTED)
    Reboot the router
    Confirm signatures are updated to new (will NOT match the article dates!)
    Save another copy of the config (cant be too safe)
    Go to running firmware, use cloud update (or local copy of most recent firmware; NOT THE DATE FIRMWARE)
    Router will restart
    Login, verify all your settings.
    Now you have a working device again.
    One thing NOT mentioned in the support post is that VPN does NOT work with the date signature firmware provided! Took a few hours to diagnose that and was finally confirmed by support a day later, and there is no fix except to use the official release firmware.
    Luckily we stagger all of the auto-updates across our deployments and only had a few units that got the update. If we had every unit that had gotten the update it would have been an absolute disaster, and it was already!
    This has now happened two times in about a year with the USG FLEX, dev team really needs to test better.
  • ThomasTakt
    ThomasTakt Posts: 1 image  Freshman Member
    Network Detective-New Adventure Badge First Comment First Anniversary
    I checked in on a USG Flex 200 I have for testing, and noticed that I it had this issue. I tried to follow the instructions baut failed on the Download. The Firmware Download links lands on a 404 File Not Found-page.
    How do I get hold on an up to date firmware image?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,676 image  Zyxel Employee
    Hi @ThomasTakt
    The link has been updated, please try to download again.
    Zyxel Melen
  • GiuseppeR
    GiuseppeR Posts: 683 image  Guru Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    edited April 2
    Hi @Zyxel_Melen and @Zyxel_Emily
    I have one last ATP200 with this bug.
    I can confirm that this guide is working also with 5.37 firmware for ATP200 (dowload links are not working anymore on your first post). Updated successfully the App Patrol Signatures.
    I have issues onboarding it on Nebula. Have you got a suggestion to do that?
  • Zyxel_Melen
    Hi @GiuseppeR
    We recovered the download link. About the ZLD model onboarding Nebula issue, please help to:
    1. Ensure the firmware is the latest version.
    2. Register on Nebula with Native mode.
    3. Access the device's GUI and select Nebula mode. If the device works in on-premise mode before, please factory default it then accesses the device's GUI and select Nebula mode.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    Done all of that. The only way to adopt it on Nebula was to force from mobile app the ZTP json email to add it via USB drive. Was there a quicker way?
