Firewall same vlan
NaUH
NaUH Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi there, we have been handed Zywall 310 Firewall
However I am not sure how to configure this, I can get onto the web interface but the rest is a little out of my wheelhouse.
We would like to place the firewall between two networks so
Network 1 --> Zywall --> network2
172.16.1.x --> Zywall -->10.255.1.x
to only allow certain ports. could someone point me to good material for this, I have looked for the manual but i can't seem to find a guide for this?
Forgive me if i missing something really obvious.
Best, Na
  • NaUH
    I would assume i would, as it stands we have decided to wait on this whilst i read the manual a bit more :P
    Thanks for all your advice
  • Zyxel_Stanley
    Hi @NaUH
    Is any VLAN required in your environment?
    How both of networks accessing to internet? Or just only intranet routing?
    Can you describe more detail scenario and topology of your requirement?
  • NaUH
    Hi There!
    We have one server that has a service running on port 1822, this server has two nics one connected to the corporate network and one going into port p1 of the Zywall
    P2 of the zywall goes into juniper switch with a static IP of 10.255.1.50 on the port and the server it is trying to reach is 10.255.1.51
    this is all ntranet routing no outbound connectivity
    So i need the server on p1 to be able to reach port 1822 on 10.255.1.51
  • Zyxel_Stanley
    Hi @NaUH
    If your scenario is intranet and without any VLAN required, you can setup IP subnet on ge3 and ge4 then without additional configuration required.
    Ge3:
    Ge4:
    Juniper switch is connecting to ge3 and server is connecting to ge4 of ZyWALL310.
    PeterUK Posts: 4,438 image  Guru Member
    Might you need a firewall policy between the ports?
  • NaUH
