How I can setup the DHCP on USG 1100. Firmware 4.33(AAPK.0)
iojeda
iojeda Posts: 4 image  Freshman Member
edited April 2021 in Security
I'm , new on the Zyxel world, I had almost a month try to make work the USG 1100, so far I was able to make the VPN connect but not traffic in and out then I notice that my DHCP is not leasing IP address to no one. If so one can help me to figure this out I will really appreciated.
  • Zyxel_Stanley
    Hi @iojeda
    In default configuration Ge3~Ge5 have enabled DHCP server function.
    Configuration > Network > Interface > edit interface configuration setting.
    According to VPN question, system will auto route traffic in the VPN tunnel when traffic SourceIP/DestinationIP are the same as LocalPolicy/Remote Policy in VPN setting.
    Does your traffic has match to this condition?
  • iojeda
    Thanks for the answer the issue was the firmware, After reset to factory the DHCP start tu issue IP address.
  • Zyxel_Stanley
    Hi @iojeda
    It's good to know the issue has resolved in your environment.😁
