"Ports 10 and 11 are no longer working.
hello
I checked by connecting port 9 to port 10, and port 9 to port 11, but the LEDs did not light up. When I connected port 9 to port 8, the LEDs lit up. I performed a reset, but nothing changed. Is there anything else I can check before concluding that ports 10 and 11 are faulty?"
Hi @edepots
If connecting a loopback to port 9 and ports 10/11 didn't cause them to light up, it is more likely that these ports (port 10 and 11) are faulty. Could you share the device's serial number with me for record?
Also, please reference this FAQ to submit your RMA:
Zyxel Melen0
What switch model? XGS1250?
yes,
XGS1250-12
Hi @edepots
Zyxel Melen0
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 667 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
