WAC6303D-S the best for a smal Hotspot System?
Hi
We have 4 Floors and need a Hotspot System. Since I have to buy everything new it must work.
I dont know which Zyxel Router I will buy yet. I looking for the WAC6303D-S the look the newest one.
For switch this one: GS2210 with an centralised Management.
I will not hany any cloud sshhtt. The Amy dont need to know what my internal network structure is.
Does anyone experience with WAC6303D-S?
I like the WAC6303D-S has 3G/4G interference immunity capability, it can avoid the signal from outside. The smart antenna can detect user location to increase the signal.
As we know, only one user connect to the AP will get the highest throughput in the clear environment. When there are many users connect to the AP, the average value of throughput will be shared and get the lower value than one user result.
But for WAC6303D-S, the performance is still good even station number is high. I guess it's because it support 802.11ac wave 2 (MU-MIMO) and provide 3x3 smart antenna.
I also recommended you to try NWA5123AC-HD, for it also support 802.11ac wave2 and 3G/4G interference immunity, so you can also benefit from the advantages above.
The difference between NWA5123AC-HD and WAC6303D-S is at the max station it can afford, and the later provides more features when managed by NXC controller,
However, it requires more information like concurrent user number, application type (video/instant message/web browser), Environment topology to recommend you the most cost-effective choice.
Hi
This AP got tested from Ascom:
ZyXEL NWA5123-AC, sw V5.0.0 (AAIG.3) / V1.02
ZyXEL WAC5302D-S, sw V5.0.0 (AAIG.3) / V1.02
ZyXEL WAC6100 series, sw V5.0.0 (AAIG.3) / V1.02
ZyXEL WAC6500 series, sw V5.0.0 (AAIG.3) / V1.02
ZyXEL NXC2500, NXC5500, sw V5.0.0 (AAIG.3) / V1.02
~10 User
What user so do Work, Watch Video, Livestreams, Isolate VoIP Stuff, 4 Virtual SSIDs,
- For the VoIP scenario, the recommend SSID number should be no more than 3. It's because each SSID broadcast its own "Wireless Beacon", too many beacons will delay the VoIP packets to be sent out.
- Since your scenario includes live streaming and video watching, 6100 series/ 6500series /6303D-S are more appropriate for you. For they've embedded 3X3 antennas, and provide higher throughput to afford FullHD video and streaming requirement.
- 10 Users is an appropriate number for each AP to serve(in good signal quality).
- As for the NXC controller, You can use it to configure APs in group without setting them one by one. Also it provides Layer3 functions like Firewall rules, Routing and captive portal. It can be an auth.server itself to provide 802.1X if needed.
Above are some recommendations to your scenario, hope it helps you.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
