DAI IP Source Guard stopped showing as working on V4.50(AAND.3)
PeterUK
PeterUK Posts: 4,429 image  Guru Member
edited August 2022 in Switch
I was on V4.50(AAND.2) and all was fine I could see the binding IP lease time but with V4.50(AAND.3) everything works but no show for binding IP leases. So is the setup i had working but nothing shows in IP Source Guard?
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    edited July 2019
    Hi @PeterUK
    Welcome to Zyxel community
    May I know the no show for binding IP leases refers to the web GUI display?
    After upgrading the firmware, the binding IP lease time disappear on web GUI, am I correct?
    Also, may I know the binding IP is static or DHCP?
    Zyxel_Derrick
    Yes the binding IP lease time disappear on web GUI normally seen in Advanced Application > IP Source Guard > Source Guard Setup and for DHCP all the setup for Source Guard is their for like VLAN 50 and Trusted port.
  • Zyxel_Derrick
    Hi @PeterUK
    Thanks for your information
    We have found the issue and is working on it
    If there is any update will let you know asap
    Best regards,
    Zyxel_Derrick
    Hi the datecode firmware seems to be working Source Guard display is now showing.
