DAI IP Source Guard stopped showing as working on V4.50(AAND.3)
Hi @PeterUK
We have released a datecode to solve this issue
I will PM you the datecode and please upload it to the device
If there is any other concern, please let me know
Best regards,
Zyxel_Derrick
5
Hi @PeterUK
Welcome to Zyxel community
May I know the no show for binding IP leases refers to the web GUI display?
After upgrading the firmware, the binding IP lease time disappear on web GUI, am I correct?
Also, may I know the binding IP is static or DHCP?
Zyxel_Derrick
Yes the binding IP lease time disappear on web GUI normally seen in Advanced Application > IP Source Guard > Source Guard Setup and for DHCP all the setup for Source Guard is their for like VLAN 50 and Trusted port.
Hi @PeterUK
Thanks for your information
We have found the issue and is working on it
If there is any update will let you know asap
Best regards,
Zyxel_Derrick
Hi @PeterUK
Best regards,
Zyxel_Derrick
5 -
Hi the datecode firmware seems to be working Source Guard display is now showing.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
