Nebula vs Android
FabioBasso
in Nebula
I had the unpleasant surprise of no longer being able to use Nebula Mobile on an Android smartphone, as it indicated it was no longer compatible. What is the minimum Android version required to run Nebula Mobile?
Hi @FabioBasso ,
The minimum supported Android version required to run the Nebula Mobile app has been updated to Android 11. It is because the adjustment of Google Play policy. We appreciate your understanding regarding this update.
Zyxel Melen1
Hi @FabioBasso ,
Zyxel Melen1
- 243 Nebula Ideas
- 6.9K Security
- 785 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
