Cannot set up ATP200 to connect to internet
newcommer
newcommer Posts: 4 image  Freshman Member
edited April 2021 in Security
Hi
I use a modem and a USG50. This device has to be changed to an ATP200.
So I use the same cables as for the USG50, where they work properly. When I connect them to the ATP200 only the green LEDs are lighted. In the Quick Setup I insert the static IP adress from my ISP and when I test the internet connection, it fails. I have upgraded the firmware to V4.33(ABFW.1) but testing fails.
Has anyone an idea, what´s going wrong?
  • Zyxel_Cooldia
    Hi @newcommer
    If the device wan type is static IP, you must to add Domain zone forwarder for DNS query.
    Go to “CONFIGURATION > System > DNS > Domain Zone Forwarder”, click “Add”
    Domain Zone : *
    Public DNS   : Set to ISP DNS server or Google DNS server.
    Query via   : Select your Wan interface.
  • newcommer
    I tried the DNS from my ISP as well as the Google DNS adress. Both don´t work. The yellow LED´s are still dark and I get no connection to the internet.
  • newcommer
    Yes, I can send it. Please tell me your e-mail.
  • Zyxel_Cooldia
    @newcommer
    I will contact you via private message.😀
  • newcommer
    yesterday I made a rest of the ATP and started the setup again. Now it works properly. Thank´s for helping me.
  • Zyxel_Cooldia
    Good to hear that.😀
    Let us know if you need any assistance.
