[NEBULA] Disable Telnet
dpssupport
dpssupport Posts: 7  Freshman Member
edited April 2021 in Nebula
Morning,
I have a gs1920v2 in nebula, no pro pack lic.
Looking at logs we are getting many people trying to hack / telnet into this device.
How do we disable or lock this switch down to reduce hack attempts
Telnet authentication failure [username: admin, IP address = 77.49.71.98]
2019-07-12 07:33:16 NOTICE authentication AAA
Telnet authentication failure [username: service, IP address = 77.49.71.98]
2019-07-12 07:33:17 NOTICE authentication AAA
Telnet authentication failure [username: cisco, IP address = 77.49.71.98]
2019-07-12 07:33:18 NOTICE authentication AAA
2019-07-12 07:33:19 NOTICE authentication AAA
Telnet authentication failure [username: super, IP address = 77.49.71.98]
2019-07-12 07:33:20 NOTICE authentication AAA
  • TomorrowOcean
    TomorrowOcean Posts: 60  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    @dpssupport
    I think you may try to configure IP filtering on your Switch.
    Destination is your Switch IP address.
    Dst port is 23. (Because Telnet is using TCP port 23)
  • RUnglaube
    RUnglaube Posts: 135  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Just wondering why do you have your switch IP accessible from internet?
    "You will never walk along"
  • Zyxel_Jason
    Zyxel_Jason Posts: 421  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Thanks for @TomorrowOcean 's information.
    Hi @dpssupport ,
    Does the solution work for you?
    Keep us posted if there is any other concern.
    Thanks.
    Jason
  • dpssupport
    For some networks we require a switched back bone with various control, thought we would try nebula for management however maybe a not correct because we cannot work out how to lock this down to only my public ip range.
  • dpssupport
    sort of, we have had to deny the following but still not sure its the right solution.
    deny 21,23,22,80 FROM ANY, have i missed any
    do you have an easier method?
  • Zyxel_Jason
    Hi @dpssupport ,
    If you want to block the traffic of FTP, Telnet, SSH and HTTP to your Switch, yes, you may configure like that.
    Hope it helps.
    Jason
  • RUnglaube
    edited July 2019
    Sorry I still don't get it. When you manage your devices through Nebula, the switches and APs don't need to be accessible from internet, unless you have specific requirements in your network. BTW, if you still need to make a device accessible from internet, the NSG - Virtual server settings have an 'Allowed remote IP' option to lock down the access to your public IP only.
    Cheers!
  • dpssupport
    Yes i have specific reasons for some network to manually set these up with a Static Public Facing IP Address, hence wanting to lock it down.
    FYI the reason is we are subletting a number of offices and these office are provided a single port on the back bone switch with a public IP address. hope that clears it up. Unfiltered service.
    We do not use the NSG units.
  • RUnglaube
    Got it, thanks for sharing 🙂
Nebula Tips & Tricks
