Cloudflare DDNS shows "Success" but the DNS record never updates in v1.39
baba
baba Posts: 293
image  Master Member
Hi all,
I'm trying to get Cloudflare DDNS working on my USG FLEX 200H, and the IP is never updated. The device reports success anyway.
Environment
  • Device: USG FLEX 200H
  • Firmware: V1.39
  • WAN: PPPoE
  • DDNS provider: Cloudflare (built-in profile)
  • Record type: A record
Configuration
  • Authentication: Cloudflare API token with Zone → DNS → Edit permission on the zone [or: Global API Key + e-mail]
  • Zone / record name: [domain.tld] / [sub.domain.tld]
  • IP address source: [WAN interface / auto-detect / custom]
Problem
  • After a WAN IP change, the DDNS status in the GUI says Success and shows the correct/new IP.
  • In the Cloudflare dashboard, the A record still has the old IP. The "last modified" timestamp doesn't change either.
  • It makes no difference whether the record is set to Proxied (orange cloud) or DNS only (grey cloud). Neither one updates.
  • If I update the record by hand, or with a curl call against the Cloudflare API using the same token, it works right away. So the token and permissions look fine.
What I'd expect
The A record is updated to the new WAN IP. Ideally the Proxied status is kept, because that's how I want to run the record.
Already tried
  • Deleted and re-created the DDNS profile
  • Created a new API token
  • Rebooted the device
Questions
  1. Is this a known issue with Cloudflare DDNS on uOS 1.39 for the H series?
  2. Does the built-in Cloudflare client support records set to "Proxied", and does it keep the proxy status when it updates?
  3. Is there a debug or CLI command to see the actual API request and response sent to Cloudflare?
    PeterUK Posts: 4,818
    image  Guru Member
    edited October 6
    This is a know issue
    DDNS Type Cloudflare not working — Zyxel Community
    It has been fixed and will be released next firmware
  • Zyxel_Luna
    Zyxel_Luna Posts: 122
    image  Zyxel Employee
    Hi @baba,
    Thank you for providing the information.
    This issue is scheduled to be resolved in the next official firmware release.
    In addition, the datecode firmware our team provided yesterday already includes the fix for this issue. Could you please help upgrade to this version and verify if the problem has been resolved?
    Thank you again for your support of Zyxel, and have a wonderful day.
  • baba
    baba Posts: 293
    image  Master Member
    Fixed in V1.39(ABWV.0)ITS-26WK37-m12845
