New with Nebula. I have folowed the guide to make vpn thrue L2TP VPN connection over Cloud Auth?
Hi @Hoffa_
Welcome to the forum.
L2TP IPSec on Windows 10 problems are known.
Quick solution is to execute, and reboot the pc
REG ADD HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
But I suggest to read the following links:
https://github.com/hwdsl2/setup-ipsec-vpn/blob/master/docs/clients.md#windows
I hope it helps you.
Best regards
Hello @Hoffa_
Is the issue persist? Could you please screenshot VPN category logs in NCC (Gateway>event log) also Windows L2TP setting for us.
/Chris
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
