LTE firmware for SBG3600
  • Zyxel_Cooldia
    Hi @Robin ,
    I will send your firmware via private message.
  • JamesW
    JamesW Posts: 2 image  Freshman Member
    Could I also be sent the latest LTE firmware for SBG3600? Many Thanks
  • Zyxel_Cooldia
    Hi @JamesW
    Welcome to Zyxel Community 😄
    May I know your router firmware version?
    Is it V1.00(AAKO.9)C0?
  • Clemens_Mohr
    Clemens_Mohr Posts: 4 image  Freshman Member
    I have updated the firmware to V1.00(AAKO.9). Since then LTE signal strengh is only one bar. Before fw update of the router I had 4 to 5 bars. I did not update LTE fw. It is ALT3100_05_00_02_00_81_MS. Do I need a LTE fw update? If so, please post me a new LTE fw version.
    02
  • Zyxel_Cooldia
    Hi @Clemens_Mohr
    Welcome to Zyxel Community.😀
    Both the V1.00(AAKO.9)C0 and the ALT3100_05_00_02_00_81_MS are the latest. Could you please recall which firmware version was it before upgrading to V1.00(AAKO.9)C0?
  • secu_guest
    secu_guest Posts: 6 image  Freshman Member
    Can I also get newest lte module firmware?
    Now its ALT3100_04_05_06_10_B8_LO
  • Zyxel_Cooldia
    Hi @secu_guest ,
  • secu_guest
    Yes
  • jsnsm14
    jsnsm14 Posts: 3 image  Freshman Member
    Can i have also newest firmware for LTE upgrade, thanks.
  • Zyxel_Cooldia
    Hi @jsnsm14 ,
