[NEBULA] What IPs and ports to whitelist
I just got a Zyxel AP and am very pleased with Nebula so far. In order to have it connect, I had to bypass my usual firewall SSL inspection and so on, so I wondered if anyone was able to advise what addresses and protocols are explicitly required for communication with the Nebula platform, so I am able to whitelist only that which is necessary.
Take a look here 🙂
Hi @Curval
Addresses: 63.35.107.114
52.48.115.44
52.210.12.1
34.247.112.130
However, it is not recommended to white-list the IP addresses of our servers. Firmware upgrade, for instance, requires downloading files from a different source with changing IP.
Instead, please white-list the AP's source IP address with exceptions to the TCP ports listed on Bayardo's link.
Thanks. Do all outbound requests go to a *.zyxel.com address, even if the IPs change?
Hi @Curval ,
Yes, it should be fine :)
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
