LTE firmware for SBG3600
Many thanks. What does it mean latest letters at the firmware name MS and LO? It is compatible with EU frequency LTE bands?
And what is WWAN driver? I'm used to the name that wwan is GSM module (on laptops etc..)
Hi @secu_guest
Regarding the "MS" and "LO", they are part of the naming rule.
About "WWAN driver", the SBG3600 supports wireless Internet connection not only from the built-in LTE module but also from USB-pluggin 3G dongle.
The WWAN driver refers to 3G dongle. It ensures the Internet availability.
Hi @Zyxel_Cooldia,
can you send me the LTE Firmware as well please?
I am running:
Router firmware: V1.00(AAKO.9)
WWAN Package Version: 1.15
LTE firmware: ALT3100_04_05_06_10_B8_LO
Yes it's V1.00(AAKO.9)C0
HI need new firmware upgrade for LTE on SBG3600 currently on ALT3100_04_05_10_B8_LO
Hi qubic,
May I know your router firmware version?
Is it V1.00(AAKO.9)C0?
Thank you.
Regards,
Bob
Hi Bob Firmware is V1.00(AAKo.9)
I have a issue, the download is very slow by LTE.
It's a firmware issue?
Hi qubic,
I will send you a private message with the firmware. Please go to the "Inbox" at the upper right side of the page.
Regards,
Bob
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
