Access Webserver on Port 8082
Hi everybody,
I got a Zyxel USG 110 and would like to access a Ubuntu Webserver from the outside.
I have a NAT rule which seems to be working but only internally in my LAN.
What do I need to set as security policy to make this working?
Is there anything else to take care about?
Best regards...
Mirko
Well yes your going to need to make a rule from WAN1 to LAN1 (where your server is) for service ARCHIVWEBSERVER.
Okay I made a rule from WAN to LAN1 but it is still not working.
Best regards...
Mirko
Is the Webserver on LAN1?
When you make the incoming connection from external do the logs show the connection?
Hmm. I get a TCP Retransmission... what does that mean? It seems to be stuck after connecting to USG110.
3 0.000000 146.0.216.115 192.168.1.200 TCP 74 38814 → 8082 [SYN] Seq=0 Win=65535 Len=0 MSS=1420 SACK_PERM=1 TSval=3663159179 TSecr=0 WS=256
4 1.009869 146.0.216.115 192.168.1.200 TCP 74 [TCP Retransmission] 38814 → 8082 [SYN] Seq=0 Win=65535 Len=0 MSS=1420 SACK_PERM=1 TSval=3663160185 TSecr=0 WS=256
On LAN1 side.. nothing.
Best regards...
Mirko
For testing change the rule to LAN1 to any
Hi Mirko,
Try to disable the firewall rule temporarily to check if the connection issue is coming from firewall rule or not.
Router(config)# no firewall activate
Hi @Mirko
From the packets trace, we can see that tcp handshake fail, what we expect is that Ubuntu Webserver reply with [syn,ack] packets, then establish the connection.
Can you also capture packets on Ubuntu server? Confirm that if the Ubuntu server receive the syn packet.
Tcp hand shake
A ------[syn]-----------> Ubuntu Webserver
A <------[syn,ack]---- Ubuntu Webserver <= Ubuntu should reply with [syn,ack ]
A ------[ack]-----------> Ubuntu Webserver
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
