[NEBULA] switch from Nebula to standalone mode
Simply unregister it from the Nebula organization and it will become factory default, booting up as standalone.
"You will never walk along"0 -
I moved the AP to another building before unregister.
However after I unregister from the cloud , I still can not get into webpage of the AP.
Even push the reset default button , I still can not access the devices.
What should I do ?
Should I go back to original place ?
I guess your device is not connected to internet and cannot realized that has been unregistered. If you already push the reset button (you might have to keep pushed for some seconds), most likely the device is using the default IP 192.168.1.2 if DHCP is not available in the network, try that one.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
