[NEBULA] switch from Nebula to standalone mode
samchiu
samchiu Posts: 2 image  Freshman Member
edited April 2021 in Nebula
Hi I bought a WAC6303DS and I upgrade to a cloud mode( Nebula) , but how can I go back to standalone mode?
  • RUnglaube
    RUnglaube Posts: 135 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Simply unregister it from the Nebula organization and it will become factory default, booting up as standalone.
    "You will never walk along"
  • samchiu
    I moved the AP to another building before unregister.
    However after I unregister from the cloud , I still can not get into webpage of the AP.
    Even push the reset default button , I still can not access the devices.
    What should I do ?
    Should I go back to original place ?
  • RUnglaube
    I guess your device is not connected to internet and cannot realized that has been unregistered. If you already push the reset button (you might have to keep pushed for some seconds), most likely the device is using the default IP 192.168.1.2 if DHCP is not available in the network, try that one.
Nebula Tips & Tricks
