LTE firmware for SBG3600
  • qubic
    qubic Posts: 5 image  Freshman Member
    did not work
  • qubic
    firmware still showing the old version
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi dcarb,
    I have few questions:
    1) Is the download speed always slow or is it a problem starting recently?
    2) Do you test download speed through a Wi-Fi connected device or a LAN connected device (e.g. a mobile phone connected through Wi-Fi or a PC connected through Ethernet cable)?
    3) Could you please identify roughly how slow is the download speed? For example, 5 Mbps?
    4) Could you please take a screenshot of the LTE Statistics page (System Monitor > LTE Statistics)?
    I would like to know the signal strength.
    Thank you.
    Regards,
    Bob
  • Bob_C
    Hi qubic,
    I reply through message.
    Please check your inbox.
    Thank you.
    Regards,
    Bob
  • Pascal
    Pascal Posts: 8 image  Freshman Member
    I am using V1.00(AAKO.9) on SBG3600. I would like to get the latest LTE firmware. Can someone help me ?
    Best regards.
  • Bob_C
    Hi Pascal,
    Could you please provide your "module firmware version"?
    You can read it from the LTE Statistics page (System Monitor > LTE Statistics).
  • Pascal
    Thanks for your help. My current "module firmware version" is :
    ALT3100_05_00_02_00_81_MS
    Best regards,
    Pascal
  • Bob_C
    Hi Pascal,
    Your module firmware is the latest version.
    Regards,
    Bob
  • Pascal
    Hello Bob,
    Thanks for your reply. I still do not understand why I haven't been able to use this LTE connection once. But that's another story.
    Thanks,
    Best regards,
    Pascal
  • Bob_C
    Hi Pascal,
    Could you please describe the LTE connection you mentioned above with more details? Maybe I can help.
    1. Could you please start a new discussion thread because this thread is for the inquiry of the LTE module firmware?
    2. Could you please provide screenshots of the Status page, the LTE WAN page (Network Setting > Broadband > LTE WAN), the Multi-WAN page (Network Setting > Broadband > Multi-WAN), and the LTE Statistics page (System Monitor > LTE Statistics)?
    Thank you.
    Regards,
    Bob
