[NEBULA] Enable SIP
@JorisK
Because we have other customers ask about SIP ALG, and the good new is now we are working on discussing this feature internally, so I would like to clarify if your request is SIP server or SIP ALG? I would like to help to transfer this to internal.
I have a issue where a customer have 15 ip phones that need receive incoming calls from internet. This way I need to create a rule permitting this incoming connections, but I don't have 15 public IP address do NAT 1:10
Hi @ZeRicardo
Welcome to Nebula Forum.
We saw you created a ticket regarding this question through our technical support channel, we will reply you through ticket. After the case is clarified We'll update once more here in the post.
Hi @JorisK
For common VOIP solutions, SIP ALG is a necessary feature if you need to make calls from inside your local network to phones across the Internet.
Calls across your own private networks should work even if you have a SIP server on the public network.
I configure ALG directly on SSH session and all works fine, but if the device reboot is needed reconfigure manually. Is important to add this feature on NCC0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
