[NEBULA] NSG50 VPN L2PT Ipsec on WAN2 don't Function
Good Mornign have a problem on NSG50 and VPN L2PT Ipsec directly on WAN 2;
I have problems with the NSG50 and the WAN 2: I create a VPN account with credentials and related cloud authentication parameters and everything works on WAN1; If I move it all, on WAN 2 it doesn't work; Since I need to work on WAN1 or WAN2 I would like to know why. Thank you. Happy August.
Thanks Andrea Sdringola
Have you upgrade to the last version? As I recall it should support connect L2TP tunnel through WAN2.
yes, the firmware is last.
Greeting @AndreaSdringola
I will private message you for org. information, please check your Inbox message. Thank you.?
/Chris
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
