Double NAT problem USG20W-VPN
bdb
bdb Posts: 11 image  Freshman Member
edited April 2021 in Security
I'm getting nowhere with my double NAT problem and I need your help.
I have the following structure, which I cannot realize otherwise.
How can I realize that I can access the server behind the USG from the address range 192.168.2.0?
I would also like to know how I can disable the log for port up/down.
Thanks for your help!
  • bdb
    here is the right plan
  • bdb
    USG as main router is unfortunately not possible. Bridge does not work either, see screenshot. How can I fix the bridge problem?
    In the fritzbox I set a static route and in the USG the NAT accordingly. Now it works THANK YOU
    PeterUK Posts: 4,427 image  Guru Member
    edited August 2019
    For the Bridge you put in br0 then then the members like WAN and DMZ but if you got statc route to work no need.
  • ChrisGer
    ChrisGer Posts: 206 image  Ally Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    Hi @bdb
    it looks like, you are useing the fritzbox for VoIP and router from your ISP.
    As already mentioned by @PeterUK , you should be able to config a routeing rule at the fritzbox, that forward all traffic from 192.168.1.x to 192.168.1.1 (WAN interface USG20).
    At the USG20 you had to disable the SNAT to forward the traffic to the fritzbox and avoid double snat first.
    Regards
    Chris
  • Zyxel_Cooldia
    Hi @bdb
    You can disable default snat at “CONFIGURATION > Network > Interface > Trunk”
    BTW, you have to add static route on upper layer router for subnet 192.168.1.X/24.
    Click “Show Advanced Settings” and untick “Enable Default SNAT”
  • bdb
    first of all thank you for your help.
    @ChristianG
    Yes, i use from the FritzBox VoIP and ISP.
    @Zyxel_Cooldia
    disabling Enable Default SNAT alone does not help.
    Under "Default Truk Selection" I don't have to set anything?
    With the USG20 I enter the following under Static Route:
    IP: 192.168.1.0 (the IP range of the USG?)
    Do I then enter a gateway or do I select the WAN interface?
  • ChrisGer
    Hi together,
    @bdb
    disableing the SNAT is only one part and do not fix the double SNAT as described.
    In your case
    All traffic from the Devices, that are attached to the USG is by default routed trough the WAN Port to the FritzBox -> that's by default working.
    You have to tell the FritzBox (by static route settings) where the reply package for the Subnet(s) on your USG should send to - in your case - IP-Subnet 192.168.1.0/24 should be send to the WAN-IP of the USG.
    If you require a connect to the FritzBox Network, make a static route on the USG and configure the FritzBix Subnetz (Gateway) to get connected to your fritzBix Webinterface.
    Good Luck
    Chris
  • bdb
    So far I have set a static route in the FritzBox:
    192.168.2.0 (IP)
    192.168.2.10 (USG)
    And a NAT rule in the USG:
    Virtual Server
    WAN - ext.IP (192.168.2.0)
    LAN - int.IP (Server 192.168.1.50)
    Release for corresponding services
    A security policy:
    For the services of the server
    From the network of the Fritzbox (192.168.2.0) I get access to the services of the server.
    Other settings failed so far.
    But this doesn't work:
    IP-TV of the Fritzbox I can't get into the network of the USG. According to the log the default rule blocks the traffic from 192.168.2.1 to 224.0.0.1 (probably a mulicast service).
    I tried different security guidelines but the firewall always drops.
    I also can't get a VPN connection to the USG.
    I activated the port forwarding in the FritzBox accordingly in the log but always no proposal chosen.
  • ChrisGer
    Hi @bdb
    IPTV require IGMPv2/3 support by the firewall/router device.
    @Zyxel_Cooldia
    can you please verifiy, what USG devices are supporting IGMP v2/3 regular by ZYXEL ?
    Here the config in a example (please change the IP as required for your infrastructure):
    USG
    WAN1-IP 192.168.2.1/24
    Static route - 192.168.2.0/24 next hop (FB-IP)!
    SNAT-disabled!
    Fritzbox
    FB-IP 192.168.2.2
    Static route - 192.168.1.0/24 next hop 192.168.2.1 (WAN1-IP)!
    Good luck
    Chris
