Recommendation Replacing USG100
I need help regarding a recommendation what to buy next.
I have a USG100. For the device the licenses are expiring and I can't renew them - so I need to replace it. The USG100 is a too big device for the company, but at the time there was no smaller option available. Today I would buy a USG40 or 60 and it would work well. Both devices are from 2014. Are they still any good for the next 5 years or better longer? The old USG100 got used for nearly 10 years. Otherwise there is the new ATP line. The smallest is ATP200. Is this device too much? I think a ATP100(?), which doesn't exists, would be great. Will there be a release of a ATP100? For the use case: we mainly want the UTM services, we have 3 Servers and 10 workstations, we need 5 people connection over IPSec. In addition we find the ATP service quite appealing.
Thanks you
Best Answers
ATP200 is the best choice.... if you have just 1 / 2 Wan connections and less than 30 Clients.
It is a new product and the bundle for all the services is comparable with USG software licence (400 € 1 year)
Hi @MRa
Welcome to Zyxel Community. ?
Based on your description, ATP200 should be okay for your requirement.
If you still have no idea, our region representative can help you to evaluate what series are suitable based on your requirement.
Where to buy: local representative
5
Hi @MRa
5
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
