Enable OpenVPN using app patrol with "Bypass_Proxies_and_Tunnels" that stops it - USG110
flavioSV
flavioSV Posts: 2 image  Freshman Member
edited April 2021 in Security
Hi, I am using OpenVPN and in security policy and nat I set the port and the IP to redirect to.
When I enable app patrol, and use "Bypass_Proxies_and_Tunnels", it stop a lot of VPN, and also OpenVPN, but I must use it.
How can I grant access?
Someone can help me?
Flavio
  • Zyxel_Cooldia
    Hi @flavioSV
    Open VPN is a kind of Tunnel service, it’s belong “Bypass_Proxies_and_Tunnels” this category.
    Most of VPN service are in this category, please set to forward in APP patrol profile if you want to use OpenVPN service.
    Double click “Bypass_Proxies_and_Tunnels” and set to forward at “CONFIGURATION > Object > Application ”
    If you want to see what Application are in this category, you can check at “CONFIGURATION > Object > Application ”
  • flavioSV
    Thank for reply, but my problem is: I wanto to block all others VPN (that I see are in Bypass_Proxies_and_Tunnels) but I want to use only OpenVPN. If I set Forward, I think all VPN are forwarded. How can I block all and use only OpenVPN? Is it possible? Or.. is it possible to delete OpenVPN block from category "Bypass_Proxies_and_Tunnels"?
    Thanks again.
