Enable OpenVPN using app patrol with "Bypass_Proxies_and_Tunnels" that stops it - USG110
Hi, I am using OpenVPN and in security policy and nat I set the port and the IP to redirect to.
When I enable app patrol, and use "Bypass_Proxies_and_Tunnels", it stop a lot of VPN, and also OpenVPN, but I must use it.
How can I grant access?
Someone can help me?
Flavio
Hi @flavioSV ,
If you just want to allow OpenVPN, you can create a customize APP profile for VPN service.
1)Click “Add” at “CONFIGURATION > Object > Application”
2)Type a name to identify this application rule, and click “Add” to create a new application rule.
3)Select a category in the drop-down list box to display all signatures of category “Tunneling and proxy services”, tick all applications and untick application “OpenVPN(Access)”
4)Create a customize app profile and add it into App patrol profile, action = drop.
5
Hi @flavioSV
Open VPN is a kind of Tunnel service, it’s belong “Bypass_Proxies_and_Tunnels” this category.
Most of VPN service are in this category, please set to forward in APP patrol profile if you want to use OpenVPN service.
Double click “Bypass_Proxies_and_Tunnels” and set to forward at “CONFIGURATION > Object > Application ”
If you want to see what Application are in this category, you can check at “CONFIGURATION > Object > Application ”
Thank for reply, but my problem is: I wanto to block all others VPN (that I see are in Bypass_Proxies_and_Tunnels) but I want to use only OpenVPN. If I set Forward, I think all VPN are forwarded. How can I block all and use only OpenVPN? Is it possible? Or.. is it possible to delete OpenVPN block from category "Bypass_Proxies_and_Tunnels"?
Thanks again.
Hi @flavioSV ,
5
- 603 USG FLEX H Series
- 481 News and Release
