SSL SecuExtender MAC without data with USG310
Pedroj
Pedroj Posts: 66 image  Ally Member
First Comment Seventh Anniversary
edited April 2021 in Security
Hi, I have problems with Secuextender for MAC Mojave.With version 1.1.8 of Secuextender
I can connect but I have no data transfer with the USG310.
What can this be?
  • Zyxel_Cooldia
    Hi @Pedroj
    If you disable security policy temporarily on USG310, can you ping to USG lan interface IP successfully?
    Disable/Enable Security Policy at “CONFIGURATION > Security Policy > Policy control”
  • Pedroj
    Hi, yes ... I have no problem.With the other SecuExtender for Windows I have no problems.
    It only happens to me on Computers with SecuExtender for MAC.
  • Pedroj
    Hi, I'm still having problems.What I can do???
  • Zyxel_Cooldia
    Hi @Pedroj
    This issue may need to remote check, I will check with you via private message.
