[NEBULA] Spotify Connect blocked by Content Filtering
Hi
Even without any category being selected, NSG is preventing me from successfully select any Spotify enabled loudspeaker from the Spotify app in order to listen music on it. Disabling Content Filtering immediately resolves the problem.
There's no information in the Event logs on the NSG. I have captured the traffic on NSG for LAN1 and WAN1, merged them in Wireshark and started with the troubleshooting. I've pulled the following HTTP hosts from the conversations and added them to the white filter on NSG which did not help:
*.edgesuite.net
*.akamaitechnologies.com
*.spotify.com
*.googleusercontent.com
Is there any possibility to debug the content filtering mechanism on the NSG? Clearly, the issue is related to that functionality. Appreciate any help.
Regards
Walter
To All,
The root cause is because Spotify use SSLv3 communicate with each clients, which considered is vulnerable and block by CF, if anyone who experience this issue please just leave the message here, I will help you.?
/Chris
Hello @blechkiste
Welcome back to the community.
May I know is there any content filtering entry in Gateway>NSS Analysis?
Since I cannot reproduce the issue, therefore I'd like to private message you about the Org. information please be aware of your Inbox message.?
/Chris
Thanks, Chris. I’ve opened a support case.
wrt NSS: no further information visible either.
Regards
Walter
To All,
/Chris
Still no solution? Having the same problem. Denon Spotify player is visible but the connection from my phone is never established.0
Hi Dave
Zyxel fixed it directly on my NSG. Reach out to Nebula_Chris. You'll probably need to open a support ticket too.
Regards
Walter
Have replied you via private message please check your inbox message.?
Having the Same issue googleusercontent.com is blocked with the MSG:Websites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for doc-0o-6k-apps-viewer.googleusercontent.com. The certificate is only valid for the following names: dnsft.cloud.zyxel.com, *.dnsft.cloud.zyxel.com
just wondering whether this could apply to my USG 100 Flex?
Fundamentally, "Spotify Connect" does not work for me on my Bluesound Node.
1.) If I navigate though BluOS to Spotify the Spotify app indicates that it is trying to connect to my Node but never succeeds.
2.) If I click on airplay within spotify and select Node it works ( but I
like to use "Spotify connect" to not be dependent on ipad after music
selection)
So, I can play spotify on my ipad, but not on Bluesound using "Spotify connect"I have the spotify app enabled on my USG on the outgoing traffic.
Local traffic is wide open.
Hello?
I found this article as well:
Is there a fix coming up?
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
