portal.myZyXel.com
jeffjohn1941
jeffjohn1941 Posts: 71 image  Ally Member
edited April 2021 in Security
USG110 behind modem. All appears well, however when trying to access portal.myzyxel.com from Config - licensing, the portal link does not function. (" could not connect". It does work from attached laptop).
I now see a warning:
DataTables warning: table id=DataTables_Table_0 - Invalid JSON response. For more information about this error, please see http://datatables.net/tn/1
Any guidance or comments appreciated. Jeff
Jeff J Purcell, New Forest, Uk and France, 44290
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    On my zywall110, I am redirected to https://accounts.myzyxel.com/users/sign_in successfully after clicking the link portal.myzyxel.com from Config - licensing.
    Could you take a video of the redirect issue?
    Maybe someone having the same question could give you the suggestion.
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    My device just registered by the way you described successfully two days ago:)
    Which browser did you use? maybe you should try again with different browser.
  • jeffjohn1941
    thanks for replies. I see that as my USG110 is behind a router in bridge mode, the link fails, trying to connect to an internal local address. Myzyxel reg etc works via web browsers ok, but auto f/w updates and signatures do not function. (No great problem).
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    Will your router do any kind of security check or block specific traffic? What if you connect your USG110 WAN directly?
  • jeffjohn1941
    Hi- thanks for your interest. Router is SBG3300. I tried disabling firewall but same result.
    The Config - licensing-registration "portal.myzyxel.com" tries to link to 192.169.1.43/myzyxel_registration.cgi where local IP is the device.
    I did try different default browsers.
    ( p.s. I shall be transferring the USG to another site shortly so will try again from there)
  • jeffjohn1941
    My sincere apologies! Apparently I had not saved my bridge settings; I repeated all steps and this time all worked! So sorry to waste your time, Jeff
  • Zyxel_Cooldia
    Hi @jeffjohn1941 ,
    Good to hear that you found the root caused by yourself.?
    Feel free to post your questions if you encounter any issue.
