NWA-1123 ACHD - Dynamic rate limit assignment via RADIUS
I am using NWA-1123 ACHD together with a RADIUS server to assign a VLAN based on the user accessing the AP. Unfortunately I have not found any way to dynamically also define a rate limit for this particular user. I know that this can be done SSID-wise, but it would be great to also have this ability user-wise (via some RADIUS attributes). Is there a way to do that or a plan to integrate such a feature? An alternative would be to have a rate limit based on the VLAN, but I have not found anything related to that.
Thanks!
Bye
Hi @Talkabout
The standard for RADIUS attributes does not define the rate limit.
Usually it is defined in VENDOR-SPECIFIC, non-STANDARD.
We will put it in our feature request queue to decide whether to do it at the future firmware version.
Thanks for your idea.
Hi Panda,
yes, I was aware that this is not supported by RADIUS standard attributes, but as Zyxel already provides some vendor specific ones I was hoping that there already is something I can reuse. But thanks for picking this up as a feature request!
Bye
- 603 USG FLEX H Series
- 481 News and Release
