[USG40W - SSL VPN] User Session Idle Timeout
Hi everyone,
is there a way to set an idle timeout for the SSL VPN Users on a Zyxel USG40W ?
My users connect to the SSL VPN tunnel using SecuExtender but if they forget to click on "Disconnect" after they're done, they are never disconnected.
So next time they want to use the VPN, they can't because they are already logged in.
Thanks for your help.
In object > user/group then edit user name you can set use manual settings lease time to 2mins but this may limit the time they stay connected but might be fine for SSL VPN or In object > user/group >settings tab Enable user idle detection for 3 mins or what you need to set it.
6
6 -
Enabling user idle detection didn't work but decreasing Lease time worked like a charm.
Thanks PeterUK !
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
