[USG40W - SSL VPN] User Session Idle Timeout
Daseg
Daseg Posts: 2 image  Freshman Member
edited April 2021 in Security
Hi everyone,
is there a way to set an idle timeout for the SSL VPN Users on a Zyxel USG40W ?
My users connect to the SSL VPN tunnel using SecuExtender but if they forget to click on "Disconnect" after they're done, they are never disconnected.
So next time they want to use the VPN, they can't because they are already logged in.
Thanks for your help.
  • Daseg
    Enabling user idle detection didn't work but decreasing Lease time worked like a charm.
    Thanks PeterUK !
  • Zyxel_Cooldia
    @PeterUK . Thanks for the instruction.
    Hi @Daseg
    Welcome to Zyxel community.?
    The “idle detection” is detected by traffic, if the device still have incoming traffic from SecuExtender client. It would not force log out user and disconnect the session.
