Secureporter traffic
Hi there,
I would like to know how much data is secureporter using for sending the log to the Amazon Cloud? It should be linked to number of user and traffic on the router but can we have an idea or check this traffic directly on the router, is there any QOS activated in the background for secureporter traffic ? I am concerned for our sites with slow internet connexion.
Thanks,
Davy
I think I have my answer. I found the gzip file in the secureporter interface under Log. These daily files really represent the quantity of data uploaded to the cloud ?
It depends on amount of data in device. Device send log/data to cloud “every 5 minutes” or “every 10 MB”. No QOS in background for SecuReporter traffic, but no need to worry about slow Internet connection on your site, because we compress file before sending to cloud(10MB -> 250KB).
I was going to ask about the compression because 5mb log file is a 60mb uncompressed file but if it is compressed on the router before upload to secureporter it should be fine.
Thanks,
Davy
- 588 USG FLEX H Series
- 477 News and Release
