Idle in disc state
Hello, i have a NXC2500 controller Fw version v5.40 (aaig.0)
and an WAC-6103D Ap
actually under this controller i have 11 ap model NWA3160-N perfectly working
i can not manage this ap and i don't understand why
it's been reconognize by the controller but no way to add in management, i attach the monitor and the logs about it
messages are : idle in init state or idle in disc state
any can help ? thank you
Hi @AleITSC,
I see that there is an offline WAC6103D-I and its IP address is 192.168.50.12, Can you ping it and SSH to it successfully?
Do all APs connect to same PoE switch or different?
I'll will PM/Email to you.
Thanks!
Hi
i can not ping it because it seems to managed, actually the ap bradcast correctly the ssid
but i can not manage
There are about 3 switch involved with vlan confiugred, but others ap works fine, very bizarre
my email is info@itsc.it
thanks so much
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
