Viruses and spam scanning of emails
Hi @Frabre,Antispam works on SMTP and POP3, it cannot scan SSL/TLS connection.Regarding to AntiVirus, it can scan smtps and pop3s. However, it need to install certificate on client and enable SSL inspection on USG since the SSL/TLS encrypts the content that is transmitted.With the SSL inspection, Inspection transparently unencrypts and re-encrypts traffic to allow AV inspect the content of SSL-encrypted connections.0
So is antispam a waste of money if i want stick the GDPR?0
Unfortunately we are also purchasing the bundle licence each year although not using the spam and AV detection for e-mails.But SSL inspection is not a solution for us since this would interrupt the end-to-end SSL encryption chain.Our e-mail traffic will be checked once with our ISP and twice at the local user machine where the e-mail client program is running. This should be sufficient.I'm with Christian, bundles without spam and AV should be offered by Zyxel as well.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
