NAS-325 - FTP - Write Permission Problem from CCTV device
IanWooWoo
I hope someone could help with a problem I am having on my NSA network storage drive.
I am trying to setup a CCTV camera I have on my network to record image and send them to the NSA via FTP. There is a test button on the CCTV camera configuration to test the FTP connection. When I click it I get an error 'user does not have write permission'. When I look in the NSA log I can see the user log in and log out so the network credentials are clearly correct, however I can't find anywhere that might stop the user from writing files to the NSA.
I tried connecting to the NSA with FileZilla from my PC using the same user details and I can drag files from my PC to the NSA. I do however see a warning that the NSA Certificate has expired, I can click past that and I get connected and all is OK. Is it possible this certificate is causing an issue for the camera? If so how do I update it on the NSA?
Any suggestions would be appreciated.
Ian
Ian
Did you specify a destination directory in the camera? As far as I remember you see all shares you have access to when logged in over FTP, but you can't write to the root.You only get a certificate warning when you use FTPes. Plain old FTP doesn't use certificates.0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
