Is it possible to disable 2.4G for specific AP's within the same SSID?
papu
papu Posts: 23
image  Freshman Member
In my use-case (concurrent operation) I do not need 2.4G for most rooms. However, there is no option to make this happen in Nebula. Setting it to the lowest 3dB seems the only way.
This is a waiste of energy and RF (beacons).
Is there another way for disabling this radio?
Thank you.
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 208
    image  Zyxel Employee
    Hi @papu
    You need to create 2 SSID one with 5GHz and one with 2,4GHz then you can use Tags to set them to dedicated AP, which should only display 5GHz or bands.
    In Radio Settings you can put 2,4GHz to 1dB if you don´t want to split it.
    Regards,
    Tobias
  • Zyxel_Tobias
    Hi @papu
    Regards,
    Tobias
Nebula Tips & Tricks
