USG Flex 200 - Detecting APs on DMZ interface
I have a USG Flex 200 firewall which I just installed and configured. Everything is great however I would like to manage my three APs WA510Ds via the USG firewall. Preferred I would like to add the APs to my DMZ network however when I give the APs an IMP in the DMZ they are not getting detected. If I give them an IP within the LAN network then they show up in the firewall. Is there a way I can enable the AP detection on the DMZ interface as well?
Thank you
Marcus
Thank you
Marcus
You need to make a from DMZ to Zywall rule I think for ports UDP 2018 and 5246
Hello PeterUK, that worked. Thank you very much0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
