How do I choose between Nebula or NXC products?
Zyxel_Dean
The difference between NXC series and Nebula is that the NXC series has more complex configurations available and require higher skillsets and networking knowledge while Nebula is meant to be intuative and simple to manage.
We would suggest depending you or your customers' needs, if advanced networking fits your demands, then you probably could consider NXC series. In contrast, if you or your customers does not have the requirements or needs of advance networking options, then Nebula would be an excellent choice.
Here are some features and comparison to the two product series.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
