Configuring SSID Not To Spill Outside A Room
businessuer
businessuer Posts: 134 image  Ally Member
edited November 2023 in Nebula
I have this request to have the SSID to not spill outside a certain area.
May I know how do I implement this request?
My AP is managed by the NCC.
  • Zyxel_Bella
    Zyxel_Bella Posts: 588 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    edited May 2022
    Hi @businessuer
    Although we can’t control the signal passing in the air such as a dedicate distance or directions. You can adjust each AP’s power to the proper value to achieve your goal.
    The setting is in the Access point > Configure > Radio settings page.
    [NEBULA] How to fine tune the deployment with configuration radio settings?
    Ensure the signal is at least -65dBm in the corner of the room or user may feel wireless performance not well. With walls, the signal will be attenuated outside of the room.
    We hope the power setting can help you.
    Welcome to sharing your application idea.
    Thank you
    Regards,
    Bella
Nebula Tips & Tricks
